Replacement Autoride Sensor Link??
jleonard711
Anyone know where I can get some replacement autoride sensor links? I've searched around and have been able to find a replacement assembly (used) on eBay for like $30, but all I need are the rods for the front & back and can't find them anywhere. And I certainly don't want to spend $60 for two small pieces like that. I did find them on a diagram with a number indicated it was a part that was available individually, but it only listed the P/N for the entire assembly.
OHSIXX
Milwaukee
Are they missing or broke? If you have the end caps just go to the hardware store and pick up a piece of threaded rod and cut it to length......
J
jleonard711
Lost/thrown out. I installed a lowering kit on the rear about a year ago and ditched the autoride system for some Bilstein's, but I liked the Autoride shocks better so I'm going back to them. I kept the stock shocks & springs, but either lost or accidentally threw away the links.
J
jleonard711
Found it!! The replacement sensor is GM p/n 22189821, and the cheapest I found them for is $20/ea on eBay.
Reyes1987
