Maxxarcade
- Joined
- Dec 29, 2019
- Posts
- 27
- Reaction score
- 26
I recently got a replacement weatherstrip for my 2011 Tahoe SSV driver's door, because it was split along the bottom where people step on it.
Before I install it, do I need to put silicone grease into the channel that locks onto the body flange?
Also regarding the silicone, I've heard that plain old dielectric silicone grease works well for conditioning the rubber. However the tube of Permatex #22058 I have does not list weatherstripping as an application. Do I need to get something different, such as the Super Lube branded stuff, or maybe some 303 rubber protectant?
I've been dealing with water getting on the driver's side floor pan, and I hope the door seal will help. It's been coming from multiple sources, but I think the worst of it was probably the poorly sealed hole where the pillar-mounted spotlight used to be.
The outer door seal that runs along the roof also seems to get water under the edge of it, but I'm not sure if it's contributing to the leaks. I would have ordered one of those too, but they are pretty expensive for the OEM part.
