Replacing speakers and sub and amp
19964x4HOE
Waterloo, IA
I have a 2001 Tahoe LT with a NON-Bose stereo system with onstar. It has the factory 8" sub in the rear and i am guessing it is all amp powered. But i am wondering if all the speakers are powered by the amp or is just the sub powered by the amp? So my next question is if i decide to replace the speakers do i have the do anything special? or will they hook up just fine?
My next question is if i decide to replace the factory sub and put a little amp in place of the factory one to power the aftermarket sub what do i have to do to bypass the factory amp? or can i use the wires that power that sub? where is the sub located?
If anyone can give me some info please let me know :) Thank you
Jaxon1023
Amp to everything is behind glove box. I just ran wires from my aftermarket radio to the fosgate speakers the po installed and ran off the amp. Sounds so much better.
19964x4HOE
Waterloo, IA
so if i replace my door speakers i cant jsut hook them up to the stock wiring?
---------- Post added at 07:25 PM ---------- Previous post was at 07:22 PM ----------
or are you saying that you ran wires form the headunit to the speakers and had the wires from the amp going to the speakers to? i ahve stock headunit and wanna keep stock headunit i am just wondering about replacing the speakers to make it sound a little bit better
Jaxon1023
In your case I would just add new speakers. When I got the tahoe it had an aftermarket radio and aftermarket speakers. They sounded like crap off the stock amp so I wired them today to the new radio I bought.
The 'ER
Minnesnowta
After market speakers will work. Just might have some fitment issues. My Sony's did not cooperate so I trimmed and then installed with self tapping screws with heads painted to match the door so no one knows.
19964x4HOE
Waterloo, IA
painted to match the door? arent they behind the stock grill on the door panel anyways?
---------- Post added at 11:05 PM ---------- Previous post was at 11:05 PM ----------
how did they sound like crap? like distorted? or barely any sound? under powereD?
Jaxon1023
I have 6 1/2 Rockford fosgates front and back. Previous owner installed them. Backs fit fine. Front he had to screw into door frame but can't see it behind the grill.
2005Suburban
