Hey all,
so I have an 03 Tahoe z71 with the from mounted transmission cooler. The line that goes to the cooler from the radiator was leaking at the fitting to the cooler. When I removed the line the cooler broke...so I need a new cooler.
long story short, there are no oem or aftermarket coolers available in my area for more than a week and I need the truck.
I do not tow...never have never will...so I wh I don’t really need this cooler. Is it possible to bypass the cooler all together by running a rubber hose from the feed to return line?
if not, I may replace it with an aftermarket cooler. My question is this: how do you connect the new cooler to the factory lines if the new cooler does not have the press in fittings? Can I just use a hose and clamp from the factory line to the aftermarket cooler or will that leak?
thanks!
thanks!
