Resetting TPMS
dcwhybrew
How do I reset my TPMS? The air pressures are being read by the computer for the wrong tires. My rear tires are sowing up as front tires and vice versa. Thanks
comerz1
Super easy, it's in your owners manual so you may want to verify, I am recalling from memory.
Set parking brake.
Turn Key to "ON" but with engine off
Turn Headlight switch from off to on 4 times within 3 seconds, your horn will chirp twice
Start with drivers front tire, inflate or deflate (or a little of both) until the horn chirps, approximately 15 seconds
Next Passenger Front same procedure
Passenger rear same procedure
Driver's rear tire same procedure
Check to see if TPMS Symbol on dash is still flashing, if so turn ignition off
Adjust air pressure in tires to recommended pressure
You're all done!
---------- Post added at 10:57 PM ---------- Previous post was at 10:56 PM ----------
Ah, meant to add, from start to finish you will have 5 minutes to do this. I started by removing all of my valve stem caps. You will feel a little like a pit crew guy running around the vehicle.
Colby82
So it is just looking for a fluctuation in a specific order?
Yes, once in relearn mode, it will honk to acknowledge that the pressure change has been recognized. Once it honks, move to the next wheel in the sequence.
OHSIXX
Milwaukee
Set parking brake.
You're all done!
Just did this the other day and worked like a charm ;) I rotated my tires awhile back and was putting this off...easy to do.
UNLIMITLESS
KINGSTON, NY
Did it but still had a problem. Dealer found bad sensor. Covered it under warranty and reset them. All good now!
cjtpilot
Accomplished this last night but now 3 of 4 sensors are reading 0. Whats the issue???????
Rfunes
