Retaining RSE (Rear seat Entertainment) in 2016 Suburban
topspeed02
NW Florida
Im getting ready to do a 2016 Chevy suburban and change out the factory 8" screen in this truck. Im using a module to swap front radio out but want to retain the RSE in the truck seeing that I just replaced the second row and the DVD player up front went out. Does anyone know of a harness to keep it? The only harness I have found so far is a 16 pin that says it only works up to 2014. The RSE harness behind the radio is a 12 pin harness. Has anyone do one or have a resource to get this done?
Fless
Super Moderator
Elev 5,280
Maybe cmatt who is on this forum or he might have a recommendation
Tip: when you mention one of the forum members in a post, use the "@" sign and start typing his/her username. A picklist will come up, select the right one, then keep typing your message. The username will change color when you post the message, and that way it'll ping the member that he/she was mentioned in a post. Like @cmatt
maestro rr
jas6104
