Reverse LEDs
houstontaylor
It's best to get a cylindrical shaped led replacement since the reflectors are designed for the point light source of a conventional bulb. Leds with two flat sides don't reflect right.
GranPrix
Pioneers on the bottom Avengers behind the glass. The Vertex weren’t activated in this picture in the reverse lights.
BlaineBug
Clown World
LED's act best in parabolic reflector housings when the light is sent left and right at 3:00 and 9:00 positions. Don't use an LED with an outward facing diode or you WILL blind oncoming drivers. However that is fine to use in your reverse lights!
Thrust
ICT
These are the same lights, different seller. If somethings shows out of stock, if it's something this generic it's likely to be sold by someone else. Sellers come and go on eBay all of the time.
These worked great! Thanks for the link.
Waiting_to_Dye
