reverse lights???
lowlows18
BrOnX, NY (10457)
about a month ago i got my tranny replaced and ever since then my reverse lights don't work...the tranny was a used one...its not a fuse or the bulbs...i layed under the truck to see if any connectors were loose but everything looks fine...any ideas???
retorq
Kingman AZ
The gear selector on the side had a connector in it, I THINK that is where it tells if it's in reverse. Double check that, it might be loose.
fyremanpat
Fyremanpat
Possibley the linkage...wiggle the selector while in reverse..through neutral and park and see if they flash on for second..if so then ther u go
lowlows18
lowlows18
BrOnX, NY (10457)
where is this??
nah its not that..i already tried that..thanks though
3ddi3
