Reverse lights
Matsu
Do cops remove the reverse lights?? On my 2011 SSV there are no bulbs in there at all.
RichardCranium
Mebane, North Carolina
Depending on the state, inspection laws might not require reverse lights. For example, here in North Carolina you do not need reverse lights to pass inspection.
I wonder if they were just missed after removing strobes, or maybe even the assigned officer took out some super bright LED's they purchased themselves (and didn't replace with a standard bulb). Either way, I'd put some bright LED's in there.......love mine.
iLikeEggs
Potato!
Oregon, USA
Likely just pulled out when they were taking the strobes out. No department will remove reverse lights to be stealthy. The liabilities are too high. What if they were in a parking lot , backed up and then flattened someone because they didn't know the cop vehicle was backing up? Lawsuit city.
medicop
Since the rear back up light and brake lights flash from the factory they may have removed them if they didn't want white to the rear or they were interfering with colored strobe/LEDs in that housing.
Joeyhosmanole
I suppose they could to avoid someone being able to tell if you are backing up or changing direction. We used to have cut off switches for brake lights.
Howdy Mike, I hope you're still active here and can help me with this. Or if another member sees this and can help feel free to chime in.
I bought a 2011 SSV and it appears that it may have had a switch to kill the brake lights like Mike mentioned.
Problem is I see no visible switch and have no brake lights. Fuses, tail lights, bulbs are good to go.
Any help you can provide for finding where the kill switch may have been wired is greatly appreciated.
HiHoeSilver
Away!
Chicago
Does your cruise control work? If not, you might just have a bad brake switch.
spectralen
Take a test light to the switch and the wires going to and from. You should be able to eliminate or confirm the whole switch area as a problem with a test light.
pipehand903
