chauncey0337
I'm not sure where it's located but you can use the grey wire from the BCM. Or you can use the green wire in the A pillar but then the camera will come on when you unlock the doors with remote. Or you can do like 2005yukonxl(Chad) did and run a relay off a switched source using the reverse wire to trigger the relay so it only powers on with ignition on and truck in reverse.
