Revotec G4
sumo
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
thanks. I went with autoluminations 6ohm resistors. I have one on each side on the fronts for the switchback led/turns.
http://autolumination.com/equalizers.htm
sumo
sumo
rhode island
Cool, let me know which size of the resistor you are getting so that I can get them as well. It's odd how the hyper blinking is so random. I've seen post where some user have their installed and never see it yet some like yourself experiencing only on one side intermittently. The lights look great on the truck btw.
so i replaced the loads with the autolumination ones, Not 1 problem ever since i put the new ones on
emann_01
anyone know if these are available in black but with the smoke lens instead of clear?
mtbennett24
My Revotec G4s came with 10ohm resistors which wasn't enough. Distributor was able to get me some 7ohm resistors which work perfect. Just swap them out no problem.
felixgun
Lafayette, LA
I ordered the vled 6ohm resistors based off peoples issues on this forum with the G4 LED tails. Mine are still sitting in the packaging because I did not need them.. at all... I actually hooked one up just to see and it ended up throwing them both off with the hyper blinking! So I put the 10ohm original resistor that came with the LED tails...
tashaa95
