kc9dre
Got off work at midnight and by 1:15 I had replaced all the steppers. Replaced the face with a white one with a trans temp gauge and had it back in the truck. Found out I have some backlights out as well. So when the needle kit comes in I am going to replace them then.
But so far here is what I have done
Sent from my SAMSUNG-SM-N910A using Tapatalk
---------- Post added at 03:24 AM ---------- Previous post was at 03:09 AM ----------
And the night view.. like I said backights are mostly out... wasn't this bad with the black face but the white has lettering slightly different. Which turns out I like.
If you have an adjustable temp soldering iron at 400 degrees without burning the board and a desoldering hand pump... it's quick easy and cheap. I got 7 steppers and 9 LEDs for less than 30 shipped
The white face wasn't either forgot what I paid for it. I just need to do needles now to silver and blue and maybe a carbon fiber ish trim. Or even silver.
I would consider reworking some members panels as well with. Case by case basis.
