CamaroJoe
- Joined
- Sep 15, 2019
- Posts
- 26
- Reaction score
- 21
Hey everyone,
Did the Atomic Fab Coilover Conversion and loving it so far. The difference it makes off road (over washboard, etc) is unreal. The only issue I'm having is that the ride is bouncy on seemingly flat concrete streets - I literally bounce up and down in my seat but the road looks flat. The compression and rebound adjustments make it slightly better, but no matter how I adjust the shocks, I can't seem to dial it out. Has anyone else had experience with dialing out coilover bounce?
It's also a very stiff ride, not exactly "plush" over bumps or imperfections. Every other NBS I've driven floats down the road and is very comfortable, but mine seems to be a much stiffer set up - bumps make it up into the body of the truck and I'm thrown around instead of the suspension absorbing them. My truck was like this from the day I got it though, so I'm wondering if there are some bushings somewhere that commonly go bad on these and need replaced?
Set up:
-Viking Dual Adjustable Coilovers in the front
-Z71 Springs & Bilstein 5160's in the rear
-Stock sway bars with extended links
-UCA's with adjustable ball joint for alignment
Thanks y'all.
Set up:
Thanks y'all.
