RKE troubles
Ron-Tahoe-07
Does anybody know why when i changed my batteries in my remote keyless entry does not work. I relearned the remotes through the DIC, works when done with process but when i walk away for 5-10min it wont work at all. Has anybody else had this problem or heard of it:Plugged: 07 Tahoe LT Factory Remote Start :emotions122:
bauer4567
Allentown, PA
From what I can read on other GM forums, it sounds like the GMLan system is "going to sleep" so to speak. One thing that worked for others with Impalas and a Silverado, is to disconnect the positive battery terminal. Then touch the positive wire to a ground spot in the engine bay (basically, be sure that there is no power to the electronics).
This will "reset" the GMLan system, and may be a simple fix for you.
Good luck.
NASTY GM
Nor Cal
I had the same problem. I took it to the dealership for a relearn of some sort. I think they charged me $150 for what took about 5-10 minutes :mad3:
R
Ron-Tahoe-07
RKE Trouble
i looked everywhere to find a fix,did u get new remotes and did u notice if there is some sort of star looking thing on the back.
as for the battery thing what does he mean turn everything off and touch it to something metal in the engine compartment :Plugged: :emotions122:
---------- Post added at 08:27 PM ---------- Previous post was at 08:24 PM ----------
all i do is take it off and touch it to the closest metal i can find,and that will reset it
bauer4567
Allentown, PA
What was meant by that was to simply disconnect all power. Easiest way to do that is take the POSitive battery terminal right off the battery. There is no real reason to touch it to something metal if it is disconnected from the battery.
Im sure some electrical guru knows why touching the positive wire (now disconnected from the battery) to anything that is grounded, helps ensure that there is no power to truck.
R
Ron-Tahoe-07
ok that sounds good ill give that 1 a try,i dont know y its going to sleep
NASTY GM
Nor Cal
I didn't buy new remotes. The dealer flashed it with a hand held device.
02Lightning
I’m no guru but, I think touching them together will discharge any capacitors that keep the computer from resetting.
stevek
Dallas, TX
Pretty much. It basically turns both the negative and positive end to negative. It literally sucks all the power out.
jonestheclem
