D6CC7F9E-2432-4FE1-BAB4-798DDDF65ADA.jpeg CCF4AFA4-CE23-48C1-92D9-7E74AC376DC5.jpeg The rear bumper plastics have been showing signs of wear and I’ve wanted to replace them. Sooner or laterI figure parts like this will no longer be available. Unfortunately these are like gold. Tahoe or Yukon pieces are like $40-50 each. Denali pieces? Left and right top pads are over &150 each shipped and the lower center part is about $350 shipped. I’ve been watching EBay and just found the left top for $30 shipped and even though it was listed as used, the fine print said it had never been installed. It was delivered today. Then tonight I found the top right pad listed as used but I looked at every close up picture and I can tell it’s never been installed either. It was listed at $120 OBO. I got it for $70 shipped. So for $100 I got both parts valued at over $300. Now I just need to find the lower one.
adventurenali92
Big Bear Lake, ca
View attachment 227602 View attachment 227603 The rear bumper plastics have been showing signs of wear and I’ve wanted to replace them. Sooner or laterI figure parts like this will no longer be available. Unfortunately these are like gold. Tahoe or Yukon pieces are like $40-50 each. Denali pieces? Left and right top pads are over &150 each shipped and the lower center part is about $350 shipped. I’ve been watching EBay and just found the left top for $30 shipped and even though it was listed as used, the fine print said it had never been installed. It was delivered today. Then tonight I found the top right pad listed as used but I looked at every close up picture and I can tell it’s never been installed either. It was listed at $120 OBO. I got it for $70 shipped. So for $100 I got both parts valued at over $300. Now I just need to find the lower one.
Sweet score! My left side has a broken clip, so it’s loose and drives me nuts! I need to replace it haha. I’m thinking when I replace it, I’ll spray paint it gloss black, so I don’t have to deal with plastic fade.
HiHoeSilver
Away!
Chicago
Wow. I didn't realize they were that expensive. I have a set of z71 ones. Are those special, too?
TheAutumnWind
very nice!
I painted mine on the denali. That turned out pretty good. I should probably do the same on the caddy.
I tried back to black in the past and that worked ok.
Mine was like that. I lifted it up, cleaned a couple areas with alcohol and used black RTV in a couple blobs, and taped it down overnight. It’s held for 2 years.
Not sure, I think it’s a Denali thing.
very nice!
I used Krylon Dual Bond in a Satin Black that closely matched the original. Gloss looked bad when I tried it. But now there’s some dings and wear. I’ll probably repaint the lower center if I can’t find another deal. It has a tiny bit of damage but not enough to spend $350.
HiHoeSilver
Away!
Chicago
@TheGreatGazoo taught me about SEM Trim Black. He did my appliques with it. Thought about trying it on the remaining gray peices on the hoe.
TheAutumnWind
I used something like that on my Denali iirc.
Edit: found the old pic.
upper pad painted and lower only cleaned/degreased. So you can see the before and after.
trim and bumper paint.
Its like a satin, not too shiny.
cofferson
