92F8102C-C30F-45EB-A47D-9F666F4D007C.jpeg FF710E7C-8591-40A8-B5C7-0406E29772E3.jpeg 21E1651E-D85D-4931-BA64-90EB4574375B.jpeg 0C901E8A-2C8C-4EA9-8732-9DA63095C61B.jpeg The radiator was fairly easy to install. I found out GM deleted the drain which is kind of a bummer. There’s just a place molded where the threads used to be and it’s actually too big to just thread for the drain plug or I would have done that. I did turn the clamp on the lower hose so it’s accessible after removing the fans so it won’t be that bad to just pull the hose and let it drain. The fluid just spilled all over after removing the drain plug anyway. 8ABB91F6-EF09-46CF-8EDB-AA7970438DF3.jpeg
View attachment 229742 View attachment 229743 View attachment 229744 View attachment 229745 The radiator was fairly easy to install. I found out GM deleted the drain which is kind of a bummer. There’s just a place molded where the threads used to be and it’s actually too big to just thread for the drain plug or I would have done that. I did turn the clamp on the lower hose so it’s accessible after removing the fans so it won’t be that bad to just pull the hose and let it drain. The fluid just spilled all over after removing the drain plug anyway. View attachment 229746
GM cheaping out. Mine didn't have a drain plug either.
ZeroHour
