- Joined
- Jan 3, 2011
- Posts
- 50,418
- Reaction score
- 17,448
Yeah, you can tell that those welds had almost no heat in them. I'd definitely see if you can't get that thing warrantied out.
send it back, see if theyll replace it for free
Ummm I have no idea who built it. Probably AllStar customs in Texas. They’re the ones who fu*ked up everything else on this truck. I’ll probably have a new cell built one day that’s bigger and fits the space better but I’m in no hurry to spend money on it right now. I will revisit that idea in the next year. It’s like a lot of things right now- the lead times and prices are through the roof so I’ll wait and see if it gets better. I know billet wheels are taking 4 months right now instead of the usual 6-8 weeks.Yeah, you can tell that those welds had almost no heat in them. I'd definitely see if you can't get that thing warrantied out.
Do you happen to have a local buddy who can weld that can make a fuel cell for you? That would be ideal IMO but I completely get what you're saying if you're going through a shop or vendor. Everything is backed up and way high on prices right nowUmmm I have no idea who built it. Probably AllStar customs in Texas. They’re the ones who fu*ked up everything else on this truck. I’ll probably have a new cell built one day that’s bigger and fits the space better but I’m in no hurry to spend money on it right now. I will revisit that idea in the next year. It’s like a lot of things right now- the lead times and prices are through the roof so I’ll wait and see if it gets better. I know billet wheels are taking 4 months right now instead of the usual 6-8 weeks.
Have your local guy weld it up. You could also get some of that tank liner and pour in it. That stuff seems to work pretty good. Hell, you may even get away with something like that now and no even have to weld it?Ummm I have no idea who built it. Probably AllStar customs in Texas. They’re the ones who fu*ked up everything else on this truck. I’ll probably have a new cell built one day that’s bigger and fits the space better but I’m in no hurry to spend money on it right now. I will revisit that idea in the next year. It’s like a lot of things right now- the lead times and prices are through the roof so I’ll wait and see if it gets better. I know billet wheels are taking 4 months right now instead of the usual 6-8 weeks.
I looked into finding someone a couple years ago with no luck. I do know a guy I used to work with that’s an excellent aluminum fabricator but he’s an arrogant di*khead that I never want to see again lol. I’ll probably look again. All I need is a super simple rectangular box with mounting tabs and I’ll cut the holes and install the pump and filler neck.Do you happen to have a local buddy who can weld that can make a fuel for you? That would be ideal IMO but I completely get what you're saying if you're going through a shop or vendor. Everything is backed up and way high on prices right now
I haven’t heard of that tank liner, I’ll look into it. Thanks.Have your local guy weld it up. You could also get some of that tank liner and pour in it. That stuff seems to work pretty good. Hell, you may even get away with something like that now and no even have to weld it?
youve just described every good welder ive ever metI looked into finding someone a couple years ago with no luck. I do know a guy I used to work with that’s an excellent aluminum fabricator but he’s an arrogant di*khead that I never want to see again lol. I’ll probably look again. All I need is a super simple rectangular box with mounting tabs and I’ll cut the holes and install the pump and filler neck.
Yep! The good welders I’ve dealt with definitely seem to be prima donna’s. Have to that work for me. Two of the best, but high maintenance!youve just described every good welder ive ever met
It mounts between the rear cross frame member and the air tank. The dims are 18” deep, 10” high and currently 20”wide but I have room for 28” wide which would make it over 20 gallons instead of 15. The 18” is set in stone, the 10” high could go to 12” I believe with a new fuel pump ( I don’t remember how much I shortened the new pump to fit but it seems it was 1 1/2-2”. ) and then I’d need to rework the fill but I’m not sure if I can angle it down any more. The 20” could be anywhere between 20-28” but hopefully 28”. So ideally I would like 18 d x 10 h x 28 w. The pump and fill nozzle I can cut out and install myself. I can’t find any pre- made ones that fit. It does need mounting tabs on the bottom, 2 front and 2 rear. I’ve looked and looked and can’t find any that will fit. It’s an odd size, the 18” deep and 10” -12” high combo seems to be the problem.youve just described every good welder ive ever met
does the tank just mount in the bed? does it need any custom work or can you just use an off the shelf tank? does the tube line up with something? what pattern do you need for fuel pump?
