Roof Antennas Delete?
kwOH
Banned
On the nnbs tho..........
Sent from iPhone 7 plus using Tapatalk Pro
Fosscore
No you cannot front the outside. To remove it, you have to drop the headliner to unscrew the nut from the inside. There is also a guide pin that holds it straight that will not all you to unscrew it. I mean maybe brute force would do the trick, but you maybe do more damage than good. Plus you won't be able to properly seal it from the inside either.
itsbeen1
lake county il
I mean after you unscrew it can you just cut wires an plugs
Fosscore
Sure. Once you unscrew it from the inside just unplug it from the harness and ditch the antenna and you can just leave the rest of the wiring stuck up inside the headliner.
The most labor is pulling down the headliner. The rest is just details.
05Single
afraid of the dark
Has anyone wired the radio to the stock onstar antenna ? Or replaced with a newer version like a nnbs fin. Maybe ptm too
GvJOHNSON
