Roof Rack Removal
okfoz
07 Tahoe LTZ,
I removed the sliding bars from my roof rack, I never have had any use for the roof rack, IMHO they are not good for much for what I use the truck for...
It was pretty easy, a T25 torx screwdriver an I was able to remove the front ones to slide off the bars.
It got me thinking, If I completely removed the rails from the roof, there are 10 bolts that hold down everything, obviously if I removed the rack I should put bolts or plugs into the holes to keep water from getting into the nuts, and to keep it from leaking.
I did not try it, but I was hoping someone has...
If I remove the roof rails, and put bolts into the holes to keep them from getting water in the holes:
1) Are the nuts simply pass through, or do they have a bottom?
2) Are the factory bolts too long and would bottom out, or should I get shorter bolts to cap them off?
Either way I would want to put something in the holes to keep water out, I used some silicone caulk to use as a thread-locker when I put it back together. They seemed rather loose when I took it apart..
3) What have others done when removing the racks?
John
GunRunner7
Banned
If you search for "rack rack remove" you should see several postings about this. I am deciding if I want to remove mine on my Suburban and from what I've read, it seems that some are either getting shorter bolts and using silicone to seal them up or getting plastic body plugs and also using silicone to seal the plugs up or getting body side molding with 3M tape and putting that on the roof to cover up the nutserts. I think if I do it, I will go with either the shorter bolts or the plastic plugs. I don't know if the hold is open or closed but if they are nutserts, then all of the ones that I have used are closed at the bottom.
---------- Post added at 03:26 PM ---------- Previous post was at 03:21 PM ----------
Here are some threads that I found after searcing:
http://www.tahoeyukonforum.com/forum/showthread.php?t=41751&highlight=roof+removal
http://www.tahoeyukonforum.com/forum/showthread.php?t=30917&highlight=roof+rack+remove
Fredw999
