Rough idle and hesitation while stopped
GearHead83
Hey guys, I'm trying to solve an issue with a rough idle and stalling at a stop, only does it sometimes, I have a check engine light with the p0171 and p0174 codes which is bank 1 bank 2 lean. I've had a diagnostic done and was told it was the fuel pump going out. I changed it with an ac delco pump and changed the fuel filter, still have the same issue. I've changed spark plugs and wires all the old ones seemed to be firing. Changed air filter and cleaned MAF sensor with sensor safe MAF cleaner, and bought a new battery. Still nothing has changed, any thoughts or suggestions would be greatly appreciated. 2004 tahoe z71 5.3l flex fuel
Rivieraracing
Have you tried cleaning your throttle body? Can't see it solving your code problems but it does make a difference in our trucks if dirty!
jesse53
From what I know you might have an intake leak= new intake gaskets. A smoke test would confirm this.
Resident Psycho
Second the intake gaskets. I just replaced mine, had a rough idle more on cold days, then it finally coded for P0171 and P0174. Easy gaskets to replace, less then an hour for me to replace, but I am a Honda tech so it might take a non tech a little longer. Parts are only about $50-60 also.
Ponchonutty
New Washington, Ohio
GearHead83, did you get this fixed? My Denali has done this twice lately but its been extremely cold outside too. So far I have gotten the P0171 and P0174 codes
G
GearHead83
Unfortunately I haven't yet been able to resolve the issue, just been baring with it lately, I will be going for a diagnostic later this week and will keep y'all updated, thanks for the replies
G
GearHead83
I think Jesse and psycho are right on this one poncho, may be the intake gaskets. I got home today and gave a quarter turn on all intake bolts and seems to help with the rough idle slightly. But I also noticed while doing this the head gasket seems to be protruding from the heads in one spot so I make be looking at dealing with a little more than what I expected, any further info for poncho and myself would be greatly appreciated. Thanks guys
kevinndiaz
