ok i can tell you that i cleaned the TB out right before all of this started... i did not remove the IAC then and when it was mentioned as a cause I removed it and inspected.. it was sticking and full of buildup, I replaced with a new one but didnt clean the area that I installed it into..
When you refer to an IAC port are you talking on the IAC or on the TB?
I will try the IAC inspection tomorrow... and the relearn, also I am getting a heavy fuel smell when i start it and for the first minute or so, not raw gas smell, but super rich running smell.
---------- Post added at 10:04 PM ---------- Previous post was at 10:00 PM ----------
grounds are good...
Not sure I have ever seen a ground at my Tstat cover, but Ill verify. Also I replaced the ALT about 6 months ago, and i do have dual batteries, but I have added additional ground circuits. I figured the NEG usually just takes the path of least resistance so if I gave it plenty of paths it couldnt hurt. I added one from the second batt to the drivers side frame rail by the header, and added one to one of the mounting bolts for the alt bracket. any input on that? neccesary?
