rse problems with gmos-100
bigemike
I just installed my jvc nav unit last night with the gmos-100 so I could keep the dvd sound. When I first installed, the aux input on my radio would play the free xm channel, then I called metra tech support and they said to disconnect the xm from behind the glove box and the aux should default to the rse.
After I did that the only thing I get out of my aux input is some static. No dvd sound. re hooked up my factory unit and everything worked as it should.
Tech support had no more options to give me........
Any suggestions out there?
B
bigemike
after talking to metra tech support the solution was to hold down the source button on the steering wheel for 3 seconds. He said they would be adding that to the manual
ghostlykeswayze
So there's no way to retain both the RSE and XM? This is disappointing considering I just paid $125 bucks thinking I could retain everything.
Anybody know if the six disc CD changer will be functional with the GMOS 100? If not, no big deal..I rarely listen to cds anymore. Any ideas what I may be able to with the space if I were to remove the disc changer.
B
bigemike
you might actually be able to, simply holding down the source button on the steering wheel when you aux input is active on the new radio might switch. But to do the xm you will need to add the xtra module from metra so you can see the channel it is on.
I simply bought the sirius add on for my aftermarket radio to keep it more streamlined than having another module stuck on my dash.
dap365
