Rubbing from rear with Autoride removed.
J444HN
Hi,
I removed the Autoride from my 04 Escalade last week replacing it with Bilstein HD shocks front and back but now I've got rubbing from the back wheels.
Should I replace the rear shock? Are the possibly designed to be assisted with the rear air hence they'll be softer than others?
Anyone have any ideas please ?
Thanks
big_b_in_PA
Billy Badass
Central Pa.
Does your rear end sag at all? I think there's a conversion kit that includes new coil springs to compensate for the autoride shocks.
kses123
kses123
Raleigh, NC
You have to change the rear springs as well. Bilstein makes a pair for this exact conversion. Stock springs were designed to be used with the air leveling in the shocks.
J444HN
J444HN
Yeah, it sags a bit now and the back end scrubs when I hit a bump or turn hard. How much are the springs? Can't see them anywhere? Would Z71 springs do the same job?
Sasquatch
Orange County N.Y.
I replaced my autoride with billstein 5100 shocks too with no problems at all. It`s slightly lower in the rear but it`s far from sagging. If i put about 500 pounds in the back it sits completely level.
Your springs must be really worn out.
EdwardsD
