rubbing issues
Ceejkay
Ft. Lauderdale, FL
ok so when i go off road or anything more than a speed bump i get rubbing. my rubbing occurs in the top of the wheel well, on the front fenders no where else. it doesnt matter if im in a turn or not. i dont have bump stops. so my question is will bump stops help that? if so do they make hydraulic bump stops for our trucks. it hits pretty hard. or would a little more crank help, i dont know how much they are cranked if any. i did put a 2" block in the rear. tire size is in the signature, along with the way it sits.
DaRosa218
The Dude abides
Modesto, California
I'd look into doing lift keys for the front and a, "Add-a-leaf" for the rear. It will give you another 2" of lift and resolve your rubbing issues. It also has a nice ride with this setup :)
Dowsewashere
Your correct they do nothing. As long as you have less than 3 boot ripples touching your ok. can we get a picture of the angles you currently sit at
Ceejkay
Ceejkay
Ft. Lauderdale, FL
angles as requested. this is from the passenger side, driver side is identical. sorry its so dirty i was offroad yesterday and havent cleaned it yet
outer
inner
Jellis02
