(bg1988) we are not quite sure our selves, he/she/him/her/it/them sometimes past's some pretty bizzare stuffWho or what is Brent?
Hmmm sadly i don't understand what you mean. I guess my english, with support by Google translate, is not good enough to extract the meaning of this words...(bg1988) we are not quite sure our selves, he/she/him/her/it/them sometimes past's some pretty bizzare stuff![]()
Brent is forum member BG1988, they changed the forum layout / format a while back and it no longer displays a "name" under the member idHmmm sadly i don't understand what you mean. I guess my english, with support by Google translate, is not good enough to extract the meaning of this words...
"Ich steh auf dem Schlauch."
Like we say in Germany, what directly translated means:
"I am standing on the garden hose."
So now my feeling is, that i will pass someday into eternity and still not know who Brent is..
Wow, thank you... Now I'm fully on the track...Brent is forum member BG1988, they changed the forum layout / format a while back and it no longer displays a "name" under the member id
That’s awesome!I fixed my problem, it was only a 40 amp fuse blown, direct at the battery. Everything works, I could load the battery as well and the Battery seems to be ok.
That was a shock in the morning....
He said : "I was in a rush and connected the battery the wrong way round"Why? The battery works, seems to have correct voltage. At the moment it don't seem that the battery was damaged.
The opposite is probably true.
There are these electronics, which should get these crusts from the plates by pulsing current.
I bombed every crust in the battery in one single shot...![]()
so if I accidentally blow a fuse I should replace everything behind it? sound logic.....I mean why even have a fuse then, just delete them that way when something goes wrong you can just go throw the whole thing away and buy a new one.He said : "I was in a rush and connected the battery the wrong way round"
an idiot for continuing to use a damaged battery... Get it load tested with a battery tester you will see that it is already damaged
I bow my head to you, who knows everything and can diagnose a battery 5000 miles away, with a few letters.He said : "I was in a rush and connected the battery the wrong way round"
if you tested it whats the internal resistance of the battery, voltage means nothing..I bow my head to you, who knows everything and can diagnose a battery 5000 miles away, with a few letters.
I have a load tester and my battery is fine, I measured it with a multimeter, she has the right volt, I have been driving the car since that happened. The car always starts....
I will sue the manufacturer of the load tester, the device must display incorrectly..
Because if you, great god of diagnosis, say that the battery is defective, then it must be be so.
So what should happen BatteryGuru1988? A nuclear explosion, a total disintegration of the matter of my car?if you tested it whats the internal resistance of the battery, voltage means nothing..
