Running board LEDs
Blue2002Tahoe
Blue2002Tahoe
After trying to use the multicolor LEDs, found out the wires were way too short and decided it'd be easier to just go with blue. I wired them to the indoor floor lights so they come on when you open the door, they look pretty good and I'm definitely happy with themImageUploadedByTapatalk1400471927.250200.jpgImageUploadedByTapatalk1400471945.841571.jpgImageUploadedByTapatalk1400471951.536563.jpg
CHUBBFRESH
Nice I want to do this mod as well! Does it fade while turning off?!
Blue2002Tahoe
Blue2002Tahoe
No, they don't fade, just turn off when the courtesy lights turn off.
Here are some closer pics and some with the lights off
ImageUploadedByTapatalk1400542020.762433.jpgImageUploadedByTapatalk1400542039.421658.jpgImageUploadedByTapatalk1400542046.700832.jpgImageUploadedByTapatalk1400542056.795761.jpg
Blue2002Tahoe
Blue2002Tahoe
ImageUploadedByTapatalk1400618592.149103.jpgImageUploadedByTapatalk1400618600.570742.jpgImageUploadedByTapatalk1400618609.780107.jpg
Thought I'd show how they're wired. I just ran the wires up the door and tapped into the power and neutral wires to the foot lights, same set up on both sides
YukonXL04
The Riverboat
Arlington, TX
Dude... No on the wiring lol come on... Hey so what did you use to mount the strips?
mharders
Just outside of Seattle
Definitely should clean that wiring up. You could drill a small hole in the bottom of the door and use the factory wire loom or at least under the door seals. Lights look good on. I want to do this in white as well @XL04 most strips use 3M adhesive backing.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Blue2002Tahoe
Blue2002Tahoe
Just wired them quickly, I wasn't confident enough In the project to drill a hole.
The strips have 3m adhesive backing. I also used electrical tape periodically along the strip, but I doubt that helped at all.
shanersutherland1
