Running rough and rich at idle
95slowhoe
Boon
Well i finally replaced the tps, and disconnected the battery. At first it ran better. But when i git back from a 40mile trip it started acting up again. No codes yet. But it still misfires and tries to die. Could maybe the coil be going bad or is bad?
oldsalt
Did you also replace the IAC? It's happening at idle right? Is it really missing or just running rough?
95slowhoe
Boon
At idle it misses and runs rough. But going down the road it runs fine.
95slowhoe
Boon
Well I just went and bought a new iac. Ill let you guys know what happens.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Don't forget to reset.
INSTALL OR CONNECT
1. IAC valve into throttle body as follows:
o Thread-mounted valve - Install with new gasket.
o Flange-mounted valve - Install with new lubricated 0-ring, using attaching screw assemblies. Tighten Thread-mounted IAC valve assembly to 18.0 Nm (13.0 lb. ft.) with 32 mm (1-1/4") wrench. Tighten Flange-mounted attaching screw assemblies to 3.2 Nm (28.0 lb. in.) .
2. Electrical connector to IAC valve.
3. Reset IAC valve pintle position:
o Remove battery cable for 10 seconds.
o Ignition "ON," engine "OFF" for 5 seconds.
o Ignition "OFF," for 10 seconds.
95slowhoe
Boon
Well I got the new iac in, and reset it. But it still misfires a runs rough. This truck is driving me crazy. To me it seems like it has gotten worse. So now im leading toward a bad coil or ignition module.
SunlitComet
OBS Jedi-Do Good
POS forum programming. cut and paste will have to work on renaming files.
--http://www.sunlitcomet.com/pdf/automotive/tahoe/92-95/1995%20Chevy%20Tahoe%20Ignition%20Coil%20Testing.pdf--
:emotions122::emotions122::wtf2:
There is a space in "pdf" which when I create it does not show when typing message. I can't get rid off so just do it manually. Sorry.
jas6104
