doc5339
Might not hurt to check your ground connections and wire conditions as well.
I know this is old but I just gotten back to my truck. OK here goes; I've got everything wired up also with a push start alarm system. I can crank it if I jump the relay but not start. Its getting fuel no problem. If I put it in neutral it will crank from the switch but not start. I have no headlights and I've checked everywhere for the lamp module that my schematics says it could be. No dice. Another odd thing I saw was when I activate my alarm the push start button goes off as it should but comes back on 2 secs later like in acc mode. I know I'm missing something, I just need some expert advice on what it could beMight not hurt to check your ground connections and wire conditions as well.
