Samsung Galaxy Tab 2 7" in Dash
sparks
Tampa, FL
im sooooo doing this. im over my avic-n3....searching ebay now for 7" tabs!
---------- Post added at 10:08 PM ---------- Previous post was at 09:54 PM ----------
who do you have the 3g service through? or does it matter?
Doverpoint
Doverpoint
Why did you just use a 3.5mm to RCA cable? The deck surely has some sort of input.
this particular deck does not have rca input.
I went with this JVC deck because it has two USB connections.
Doverpoint
Doverpoint
i went with a WiFi only model because it is cheaper, no contracts, and i simply tether through my iPhone via Bluetooth. My thinking is that if I went with a wireless model i would always be restricted to that service, whereas by tethering through the smartphone, which i renew every year and a half or so, i will have scalability to always have the latest internet speeds, e.g. 5G or 6g in the future. There is no speed difference whether you tether to your smartphone, or use direct wireless service.
---------- Post added at 10:27 PM ---------- Previous post was at 10:21 PM ----------
Well that isn't very handy for this install :lol2:
actually it is because i used the front usb for the bluetooth dongle, and the back usb to connect to my iphone.
You cannot connect the Samsung Tab directly to the aft usb because it wont charge the unit. It will however charge the iPhone and I suspect the iPad as well.
I have been reading that Apple is working on a 7 inch iPad which would be a better platform over the Samsung Tab because of this USB issue, but i would bet that JVC is probably aware of the growing android market and will make future models more android friendly.
...and don't count out a mobile windows 8 tab...i heard samsung is working on one of those too.
sparks
Tampa, FL
makes sense, except i wonder how maps would work without service - if i had to take a call or something and it shut down the tether....
Doverpoint
Doverpoint
There is an internal gps in the Samsung Tab so it does not need to be connected to the internet to navigate.
...unless you are using the Waze app or something of that ilk, which is social media and navigation together...you chat with other drivers.
a phone call does not interrupt tethering.
yates ™
Resident Apple hater
Iowa
Why not use get a headunit that has bluetooth built in?
Doverpoint
Doverpoint
oh, an my service for my iPhone is through AT&T. I have the 3gig of data plan and i have not come close this amount a month, and i am tethered all of the time.
---------- Post added at 10:36 PM ---------- Previous post was at 10:34 PM ----------
you can, but i hear the range on those are fickle. Bluetooth is very low power. Having it stick out a little on the face of the JVC is a better position for the Bluetooth antenna.
yates ™
Iowa
My Clarion DD has built in and works perfectly. Not hating just was wondering those things.
Doverpoint
Doverpoint
Built in Bluetooth units tend to favor receivers in front of them. My TAB is mounted above and ever so slightly behind the front of the JVC. To get to the TAB the RF Bluetooth signal would have to go through the metal cage of the receiver, which would want to act like a Faraday cage and ground the signal, making for a weak connection. I am not saying the built in wouldn't work.
Alphamods
