**** Sensors???
Roccomac
2002 Tahoe
I recently pulled a P0332 code for rear bank knock sensor low or no connectivity after Check Engine Light came on. I did the TSB on it replacing both sensors(rear one was corroded) replaced wiring harness...the light comes back on every time for same thing. I have check connections tried bypassing, etc. Light will not go off...what to do next? Can you test the sensors without taking off intake again? Any help appriciated
dph1994
