2003 6.0 throttle body question
markman57
I have a 2003 Yukon Denali with a 6.0. There I a plug for the wiring harness that pushes in the front corner of the throttle body. About every 100 miles or so while driving my traction control light will come on and I loss all power. The vehicle goes into creep mode. I will pull over, shut off the vehicle, open the hood and jump up on the bumper and wiggle that connector. Clos the hood and start it back up. Traction light will be off and everything is back to normal. Now it will set a throttle/pedal position sensor switch A/B voltage correlation when this happens. I’ve gone to the salvage yard and found another plug but off an 5.3 and cut off about 4” of harness with it but the wires look slightly smaller. The plug looks identical. Should I worry about the wire size or go ahead a splice it in.
My other issue is a code PO300 which is a random misfire. This will set only when pulling a trailer and going up a fairly long incline with slight acceleration. I can not feel the misfire at all. Anyone else ever had this. Should I start another tread on that code issue? I want to correct these issues as I get tired of the check engine light on. I do plan on checking the plugs as I don’t know how long they’ve been in. The previous owner did change out all injectors, wires, plugs but it’s been 40k miles ago. I’ve only had this vehicle for about 5k.
My last code is a P0420 which is car system efficiency below threshold bank1. I am changing out all 02 sensors tomorrow.
When I bought this it was setting a lean bank 1 and bank 2 but I corrected that with a new MAF. All other codes were in it as well when I bought it.
Thanks for any help
Rod
04 tahoe z71 i have had loss of power issues . I too would wiggle the plug to the throttle body and it would resolve the issue so I had I replaced and I still did it . I also have replaced the throttle body and the accelerator sensor and it still does it. ok so here is the kicker I can resolve the issue by opening the hood and then closing it, it was not a bad plug or anything else but the action of the hood opening wiggles or stimulates the ground strap then it starts just fine anyway that's where I am at now I think I will add or clean up some ground connections next, hope this helps
Fless
Super Moderator
Elev 5,280
The wires from the throttle body connection to the harness are known to get compromised or break under the insulation. Carefully inspect the throttle body connection harness back about a foot. You may need to feel the insulation to be able to feel a break underneath the wire jacket.
HamptonGarage
