Service 4wd help
Hardbody255
Hardbody255
Fless that's what I was reading but wasn't sure. Because most of these codes are contradicting each other.
I think C0306, 321, and 327 are related to the encoder motor, and may be cleared with the work you've done, although it would be good to see if they are still there. Before having anything programmed you might dig deeper into the rear driveshaft (propshaft) speed sensor. Then, again, it might be caused by the TCCM needing to be flashed or a connection issue. Hard to say.
Hardbody255
Hardbody255
I'll have it scanned again and see what it says. I did notice the other day my speedometer wasnt working right then it started working like it should.
PistolPeteandDuda
