service stabilitrack/abs
gaboyls1
So I get in my hoe this morning drive to the store on the way to work. Go in store come back out and crank it up. 1st thing I noticed it was kinda hard to pull into gear then when I got her into gear the abs light and service traction control light came on. I have read a on the net all kind of fixes but they all seem to pass away alot of time before the fix. So what's the simplest way to start to run down this problem. Truck also drives normal as usual. Even tho its way colder here than usual.
Sumter SC
Mine come up saying all that but it wouldn't go into gear had to tow it to the dealership where they replaced a brake switch that talks to the computer saying the brake is applied and allows it to shift out of gear. I'm not saying that's your problem but that's what ours was.
GM Customer Service
Michigan
gaboyls1,
Hello! I am sorry to hear that you are experiencing an issue with your vehicle. I am more than happy to look into this concern for you. Please private message me if I can assist you any further.
Regards,
Jennifer T.
GM Customer Care
DogBoss
