I have had three instances in the past month or so when I have gone to start my Tahoe (2005 Z71) on cold mornings and get the "Service Tire Pressure Monitoring System" notification on the instrument panel and the battery light stays on after starting. The TPMS light (or, should I say the low tire pressure light) does not illuminate. If I let the Tahoe warm up for a couple minutes and shut it off, then immediately restart it the battery light is no longer present and I do not get a recurring "Service TPMS" notification.
Has anyone else had this problem?
I checked my battery: 12V cold
I checked the voltage at the alternator while running: 15.4V this morning; voltage at the battery is also 15.4V
Alternator was replaced about a year ago and haven't had any issues with it since.
Belt looks fine, as in no cracking
