Servos
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yes its all thru the bottom pan. If you have the trans out of the truck doing the converter you can do it on the bench.
Big Buttons
Big Buttons
The SS Burb
South Texas
Alright, does it come with directions? Ive just about completed my automotive degree so know to do a lot just auto trans I dont like to mess with. Might just wait till I get the money do to everything. Probably end of jan.
---------- Post added at 09:02 PM ---------- Previous post was at 08:57 PM ----------
So whats the $200 difference between the two packages? They look really similar?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yup sure does. Tells you what to drill and springs to use
samwilkie
Cleveland,TN
i have just over 150,000 on the clock would it still be safe to put the vette servos in. ive heard different things..thanks
josueh95
i installed the corvette servo on mine with 129k miles about a month and a half ago and i can honestly say its the best 20 dollar investment you can make :D the shifts feel alot more firmer bt not enough to feel unconfortable defenatly makes the truck feel more respinsive with no slipping in the trans
Big Buttons
Big Buttons
The SS Burb
South Texas
I've had my servo in for about a month and I love it. I even have the line pressure turned up a bit so its even more firm now.
saif najd
Could you please explain to me what is this? And where it should fit?
Big Buttons
Big Buttons
The SS Burb
South Texas
It makes your shifts faster and firmer. It comes stock in the transmissions that corvettes use. It takes about 30mins to put in, in your driveway. I had a lift so took me about 10mins. Highely recommended for all 4L60e transmissions. It also holds the band inside to prevent slipping.
Here is the link I bought mine from.
http://tinyurl.com/avxvj75
saif najd
Ok cool so I dont have to take the transmission out to fit it?
By the way I found out when I had to replace the transmission fluid that I cannot use the filter from the 98 model I had to fit the 2001 model filter (fully black plastic not metal)
So can I still use this mod?
And I was told that tahoes from 2001 and above can use the buddy valve from the 2006 models to get the best shifting, is this true?
Could you please use another link because the link you used is blocked hear :banghead:
---------- Post added at 02:34 PM ---------- Previous post was at 02:21 PM ----------
Yah right and I was told that the transmission I have use the same oil pan and transmission filter from the v8 holdens
Start from the WH model (this is the model I mean)
http://en.wikipedia.org/wiki/Holden_Caprice
And this is the info about Generation III
http://en.wikipedia.org/wiki/GM_LS_engine#LS1
I found it, hear you go :)
http://www.ebay.com.au/itm/4spd-Auto-Transmission-Filter-Kit-Holden-Monaro-V6-V8-/400276374678
bobwit2bs
