tahjoe
- Joined
- Nov 15, 2023
- Posts
- 16
- Reaction score
- 10
2019 Tahoe LT 4x4 with 65k miles. If I’m coasting at 40mph+, lift my foot off the gas pedal, and then lightly accelerate, the rpm gauge slips several hundred RPMs (even though I’m giving the car more gas) before catching. Makes merging on the highway a pain. This issue is repeatable at various speeds. But it also disappears (or seems to) when I’m in manual. Transmission usually runs around 190.
Took it to a dealership tech who said car is just “searching for the right gear,” but that I shouldn’t really feel the shift. They said that the transmission looks good, that 190 is a normal running temp, and that it was likely just a programming issue. He said it may be worth reprogramming the TC to disable [whatever it’s currently doing] in gears 1-4.
No codes / have never flushed the transmission.
I’m assuming the issue is my TC. I’m also assuming my transmission is chock-full of metal shavings and will fail sooner rather than later.
If I replace the TC and my transmission subsequently fails, would I be able to re-use the aftermarket TC? Or does the TC get fried whenever the transmission fails?
Goal is to delay the inevitable as long as possible, but I also don’t want to end up buying a new TC twice.
Appreciate y’all’s thoughts
