Hid nothing more than 25w. Bulbs sit too close to the lens and anything higher run the risk of melting. Trs sells a led direct replacement fog light that's is way better than hid or led bulbs
I think I found them:Hid nothing more than 25w. Bulbs sit too close to the lens and anything higher run the risk of melting. Trs sells a led direct replacement fog light that's is way better than hid or led bulbs
Did I pull up the wrong ones?Hid nothing more than 25w. Bulbs sit too close to the lens and anything higher run the risk of melting. Trs sells a led direct replacement fog light that's is way better than hid or led bulbs
No those are them. Pop out the old ones and pop these in. Plugs right in to oem harmess
iv always heard that 35W is the highest you want to go. Anything higher at any space between lens and projector will melt the housing.
Also hasn't everyone on here been going with 35W I didn't even know they make less than 35W and if they did would that even be bright enough for low beams?
