Should I worry?
YukonJ
South Carolina
OK so the other day I'm driving home from work...it's raining so the roads are wet. I got to make a right turn off one road to another after making a stop and the rearend feels like I've got a flat. I pull over and check and find nothing wrong. I get back in and continue on and later when making a left turn, same scenario, it feels like the ass end is dragging. It hasnt seemed to do it when dry, not that I've noticed anyway. So my question is, does it sound to ya'll like my suspension is going? Is there a sway bar back there? I have a 2001 Yukon XL 2500 with the autoride suspension.
Thanks.J
01yukonslt
need more deebeeeez!
Spokane, WA
wonder if its kicking in auto 4wd when you are turning on wet pavement? do you drive around in auto mode or does your truck even have it?
blueflamed03
Oklahoma
maybe pull rear diff cover, check R&P...wont hurt to change fluid anyway, give it a once over maybe.
waxworkz
traction control? i know when one of my tires spins the traction control takes over and it feels like power loss. its default is on, switch to defeat
Y
YukonJ
South Carolina
Thanks Blue, I'll try that. And I don't think the wheel is slipping or spinning, I'm not going hard at all.
Dewd
