side mirror blinker replacement?
ReaperHWK
2015 Tahoe LTZ. My passenger side blinker (the arrow on the sideview mirror) the LED's need replaced. They are very dim.
Does anyone know the lowest replaceable assembly for this? Can I just replace the LED board, or do I have to replace the entire glass, or do I need the whole mirror?
Thanks.
ReaperHWK
ReaperHWK
Use your fingers it is easy to pop out
That’s what I thought. However I found this video saying you need to pry it up first. I guess I’ll look at the new one and check out the clips.
RST Dana
OH
Prying is fine, as long as you use your hand. Anything else could chip or break it.
Fless
Super Moderator
Elev 5,280
I don't know what the circuit board looks like, but you may be able to fix it by touching up solder joints with some solder that has lead in it.
Tahoe2024
