silverado rear axle to tahoe?
josueh95
so there is a silverado i found for parts that has 4.10 gears..is there a way i can swap the differential or axle from the silverado into the tahoe? or is it different? thanks
http://denver.craigslist.org/pts/3849401979.html
i know this is an 8 lug right? but is there any way to benefit from this instead of buying parts nd having a mechanic install the gears or is that the cheapest, easiest way to do it?
Blazed
Accepting Donations
If it's an 8 lug I bet it isn't the 10 bolt so you essentially can't use any of that without major modification.
blanchard7684
