Slopy / loose steering? EVO sensor maybe...
bikerglasses
Still trying to find out part #....Emailed gmpartsdirect with your pic and nothing back. Willing to try this if its not too expensive.
Sent from my DROIDX using Tapatalk 2
popo8
I wonder if THIS fix translates over to my vettes loose steering....
thanku for sharing...
TapaTalk ROCKS!!!!
Doverpoint
So I read this thread, and decided to try disconnecting the sensor and then took a drive. I found that my steering was super sensitive, almost dangerous. I pulled over and plugged it back in. My steering did not switch back to normal operation! When I had plugged the unit back in I never turned the ignition off (I know...I wasn't thinking), and I heard relays clicking somewhere. I pulled over again and this time turned the ignition off and reseated the connector. Restarted and everything was fine again.
The moral of the story: make sure you turn your ignition off before plugging and unplugging connectors.
electro
Kitchener, ON, CAN
I researched my steering issues pretty extensively a while ago and I more or less concluded I would try changing this sensor. My truck drives/steers/handles terribly and after reading what the sensors job is I said that's got to be it.
I went to nearest gm dealer and they told me the part was discontinued.
Canada. Gm dealer.
Yet you just went to dealer and got one. Wtf
---------- Post added at 08:46 PM ---------- Previous post was at 08:39 PM ----------
http://www.gm-trucks.com/forums/topic/81519-steering-wheel-position-sensor/
jem556
KY
So if I understand the gist of this thread, over-sensitive steering response would be a symptom of a bad sensor but excessive play in steering wheel would not?
Sent from my DROID Pro using Tapatalk 2
pugnaxx
