Some Problems with 98 Tahoe
Hoefan
Germany
Hi there,
ive some problems with my 98 Tahoe.
A few months ago the ABS dont work correct. When i use the brakes at low speed (>20 mph ) the ABS makes noises an start working. But there was no reason for it. No wet street or mud. ABS Lamp is on.
So i decided to change the complete wheel bearing with new sensors. ive read that the sensors make problems sometimes.
After changing all was fine and the ABS works.
Since a few weeks there are new problems.
When i start the car an drive a few meters the ABS makes noise and start working BUT I DONT PUSH the brake pedal ?! ABS Light is on.
i tried to find a mistake with my obd2 scanner and scanmaster, but it seems that the ABS dont save problems like these.
We checked the sensors with a multimeter, but my sensors had the same results as some sensors from a friends tahoe.
Now i dont know how to find what kind of problems my Tahoe has ?
Is there a Software or another way to find out whats wrong with the ABS ?
Next problem ist the power steering. When i drive a short curve the servopump makes a noise. Seems that its broken. When i buy a new Steeringpump can i use the old reservoir ? or should i take a Pump with a new reservoir ?
A few weeks ago i changed the power steering sensor at the steering column without any effect ?
A Friend could steer his Tahoe with the little finger.. i need my hand to steer mine.
Last problem is the seat heater in drivers seat. ive searched some webpages but i dont find the correct seat heater for my Tahoe.
Can someone tell me where i can buy a correct seat heater ?
I hope someone can help me with my Problems.
(sorry for my bad english)
thank you
Hoefan
chauncey0337
MLT, WA
As far as the abs, I'm not very knowledgeable in that area, so I can't help you there but I'm sure somebody will chime in to help.
For the power steering, most of the pumps I've seen come with the reservoir.
I searched a tiny bit for the heated seats and didn't come up with much but I did find this below. If it's not to your liking, I would try another search using other models that use the same interior- yukon, suburban, escalade, silverado, sierra, avalanche, etc. Good luck.
http://www.heatedseatkits.com/heatedseatkits/index.html
OklahomaSideShow
