Some sunroof questions
Jobi-Wan Kenobi
I was working on putting my interior back together yesterday after my headliner being out for a while and noticing some oddities with the sunroof.
When I close the window it stops moving before its completely closed but if I bump the switch a couple times it will close the rest of the way. Anyone experience this? Is this an alignment thing with the slider deals on the track?
Also, sometimes the sunroof will cycle open and closed when I turn the ignition off. Why is that?
MassHoe04
Western MA
With the sunroof closed, remove the switch and see if it still cycles open/close with the switch removed and you turn the ignition on/off.
If it stays closed, BINGO! Switch problem.
I would be shocked, if it wasn't a bad switch. But that is still a possibility...
swt_wxw
