Sooooooooooo
1999hoe
aka HOVERHOE
Massachoochoosetts
apparently my axle seal is gone and dropping grease in the drivers side brake drum along with my differential seal is also going now i gotta replace the drum,shoes, brake cylinder and all the hardware.....
foreverfalcon40
It happens...I just did that not to long ago.. Seal was less then 5 bucks...cheapest part costs the most dmage!
puckhead
CO
Damn that sucks dude, good luck fixin it though
black95
Freeport,NY
One of my axle seals is going, also.
Are they hard to replace?
they arent hard at all. maybe 1 hour job doing both side w/o a lift .
removal
1)remove differential cover
2)Remove 8mm bolt on pin
3)remove large middle pin
4)push axle straight in(c-clip will fall off)(do not turn axle when removing)
5)pull axle straight out
6)pry seal out
reassemble
1)Push axle in ( do not turn), align in spider gear, push in until axle stops.
2)replace c-clip
3)pull axle towards you until it stops (maybe 1/2in to 1 in)
4) place large middle pin back in
5)replace 8mm bolt (non perminent lock-tite)
6) clean and reseal differential cover
7) add oil
305Tahoe
might as well do a Rear Disc conversion!!!!
hit me up if your interested...
992door
Greenville, NC
Hey atleast you dont have to do what i did and rebuild the whole rearend. Spent 1000+ on that. Could be worse.
1999hoe
1999hoe
aka HOVERHOE
Massachoochoosetts
i know but after spending that 550 on the distributor gear and tune up this truck act like it knew i was tryna save my tax money and was like ahhh no **** that your spending that shit on me ..........
992door
Greenville, NC
oh yea and i spent 1500 on a trans rebuild probably less than a month before that. It will get better just give it some time. Got to take the good with the bad
ravingmadman
Chief Knuckle Buster
Greater Seattle
If you have a rear wheel cylinder leaking, it will give the exact same appearance, FWIW. Also a super easy fix.
:drunk:
Dieseldr
