Sounds like the Windows open?
Illnasty
New Jersey
2002 Denali and it sounds like the windows open on the driver side door. The window is not open but that's what it sounds like. I'm actually having a hard time tracing exactly where the noise is coming from but it seems close the inside side view mirror cover. Only happens on the highway when going 75+ or when it's really windy out. The rubber around the door looks fine so I'm kinda at a loss here. Any ideas what to Che k?
fiatdale
Houstons Best
Houston
It probably is the weather seal around the door opening. It can leak in when you have a good crosswind - usually down the A Pillar. You can do one of two things: get a new weather seal, OR remove the seal from that area, grab a 2x4, put it up against the pinch weld area lenthwise, and give the pinchweld a good whack outwards. Not a ton, maybe 1-2mm. Put the seal back on and you should be good to go.
Rivieraracing
My guess is that your door hinges are sagging and are in need of new door pins/bushings! That's where I am with mine and I have the same noise
Illnasty
Illnasty
New Jersey
Door is sagging for sure, you nailed it! I checked the weather stripping and it looks good. Sucks that I live in a condo development with no access to a garage or I would fix so much that's wrong with the truck. Drives great but she looks so beat up. $1000 worth of work and I probably wouldn't even drive my 2016
