Spare Tire Lock Rusted Shut - 2007 Yukon XL
pmillen
Omaha, NE
The ignition key is supposed to unlock it but it won't turn. I've sprayed in a WD40 look alike and Kano Kroil Penetrating oil. No joy. Any suggestions?
89Suburban
Bull in the china shop
SE PA
I had to use a cut off wheel to get mine off.
@Tonyrodz might have a better soloution.
Fless
Super Moderator
Elev 5,280
You're sure it wasn't changed to a different key? If you have a key that's not as worn as the one you're using, try it as that cylinder may not be worn like the key always used in the ignition.
89Suburban
SE PA
Sorry guys I misunderstood. Thought it it was the locking tab on the winch itself.
P
pmillen
Omaha, NE
I'm the original owner. I don't recall changing the ignition, but I don't recall a lot of things. I'll try my wife's key. Thanks for the suggestion.
Probably clogged with crud. We run ours twice a year to prevent that. Worst case, you could cut the plastic tube from underneath but think you'll have to pull the bumper cover to get the lock out, don't remember and can't picture it right now.
Archie_III
