Spark Plug Fun - 2017 GMC Yukon Denali XL
Darkstar72
I wanted to share the joy I had swapping out the plugs and wires on my 2017 GMC Yukon Denali this past weekend. I watched multiple YouTube videos to prepare myself and give me a plan of action going forward and boy was I glad I watched a few people do this job. I used every single tip/trick that each person shared in their video on getting the dreaded #8 plug buried behind the a/c lines on the pass side. The drivers side is really straightforward with everything in sight and nothing really special there. Just kept swapping out extensions and swivels depending on which plug I was going for. The fun really starts on the passenger side and this is what I did...first jacked the truck up, took off the pass front wheel, and then removed the wheel well liner. According to some videos this is all you need for access...I still was not having an easy time. I went back up top and pulled the plastic retainer out of the metal bracket off the pass side valve cover for the heater hoses for a better grip on pulling the wires off the plugs and coils. You just use a bungee cord to hold the hoses off to the side so they aren't in the way. Got all the wires off OK except for number 8 which involved some contorting of my hand and just good ol' disregard for keeping skin on my knuckles to get it off. No possible way did I see an angle to get number 8 through the well so I went under the truck but was still having a real hard time positioning a socket on it with the exhaust manifold heat shield on as it really cut down on room to maneuver. The heat shield is only three 10mm bolts so I decided my life would be better if this wasn't in my way. I got it off really easily and that may be the fact I live in the south where rust/corrosion aren't really an issue. Taking that heat shield off made things much better to get a socket on it and get it out. The other three cylinders on the pass side are very easily done through the wheel well with the liner removed...straight shot.
In summary...when deciding to devote a couple hours of your life to this once relatively easy task I highly recommend removing the wheel liner on the pass side, using a bungee cord to pull those heater hoses off to the side after unclipping it from the metal bracket, taking off the manifold heat shield for more room to fiddle around in there, and laying under the truck and going straight up from the bottom to reach cylinder 8 spark plug.
i adapt a spark plug socket down 1/4' then use a swivel head ratchet like this one and a breaker bar over that and easy peasy
the swivel head allows just the right angle for clearance
Thank you for your write-up on your experience. Much appreciated.
clogan2
I had so much trouble just getting the wires loose from the plugs that I gave up after three, and paid my local shop to do the other 5. Decided I was too old for all that trouble and contorting.
RB_Trucker
Redondo Beach
It’s nice to see other accomplish this task their own way, I usually do wires and plugs at the same time so I have no cares on what happens to the wires, but yes that #8 plus has been and will most always be one of GM’s most hated parts
Just don’t forget the dielectric grease for the plug boot and coil pack boot, most of my plug wires tore apart because they “sealed” themselves to my plugs.
Smityinms
