Hello Everyone
I recently decided to change my 09 Denali's spark plugs.Having changed many spark plugs on other things I knew I would be able to.The first three plugs on the right side came out just perfect.Pulled out in the socket and put new ones back in perfectly.The last on the ride side Cylinder 7 I think, it was in there pretty tight.So without thinking i used my 1/2 inch drive breaker bar.It came loose but ended up jiggling around a little too much.So i kept jiggling it and eventually it broke in half right below the part where you turn to take it out.So all that is left is half of the porcelain and the lower half with the thread.I have no idea how to get it out.I don't want to use the screw extractor if I don't have to.Also cylinder twos spark plug has the same issue where I needed the breaker bar.But instead of jiggling back and forth it just keeps spinning.Thanks so much.Been stuck on this for a few days :/.
