SPC 86375 Camber/Caster Kit
MeanGreen03
TX
I'm about to install theses and need to know if I have to elongate the slots in the stock brackets. I know I dont have the full adjustablitly of them. Just curious as the instructions say nothing about doing this.
M
MeanGreen03
TX
No, it's the cam plates. They will go fully positive but there is like ~3/8" of slot left to get to full negative. I want to say that I saw a thread a while back that you had these on yours but maybe I am mistaken and you had the bushings instead.
Max
Mile High
Denver
Oh word I didn't know you had the plates, here is a better guide and yes you will have to elongate the holes to get more adjustment:
http://belltech-store.com/aca_php/import/images/4951.pdf
I still haven't done the UCA bushings but they're pretty easy to do with a press. These nittos are quite forgiving with the slight negative camber I have going on, I do need to dial some up as the vehicle will drive better with proper camber spec.
M
MeanGreen03
TX
Thanks Max! That's what I was looking for. The wierd part is that mine wont go to the max slot the other direction (which is the section that I will probably need). I guess I can just clearance on the opposite side... I bought some DJM upper arms and they can only align to almost 3* positive camber so I'm going to have to go back to stock arms. I also added some drop spindles so that may have compounded the situation.
Steven94
