Speed limit sign?
tmill260
I believe the circled white block is for the speed limit sign, how do I activate this? I assume it’s thru on star? I appreciate your help!
selectsplat
You need a data plan. The $25/mo connected vehicle plan from onstar will put the speed limit sign back, as well as the google assistant and the built in navigation. I’ve also heard that you can connect the vehicle to a hotspot from your phone to get these services, but cannot confirm.
Redmanf1
Does anyone have any other info on this? (2023 Premier speed sign??)
Thanks
WalleyeMikeIII
Sunny and Snowy Minnesota
Must have active data plan...and download offline map on your Head Unit. If your vehicle is new, it may take a couple days to get the offline map downloaded if you are taking short trips. Force it by connecting your head unit to your at home wifi, then launch google maps, hit the settings gear, select offline maps, and force the download of your home area...your sign will start workin...but, unless you subscribe to a data plan...it won't work...
mconrad58
